JustinTuaylou Posted July 1, 2010 Share Posted July 1, 2010 Hello All, I've got a problem with edge chamfering in 3ds Max that I hope someone can help me with. I have included simple images to illustrate what I am talking about. If I create a depression in a surface using a negative extrude (ex. a stream or dirt road) and then try to chamfer the edges around it, the chamfer occurs in the opposite direction. I have also found that there are two edges created in the same place, and welding them doesn't solve anything, it only complicates the problem. Thanks in advance for your help. Justin Link to comment Share on other sites More sharing options...
abmitalia Posted July 1, 2010 Share Posted July 1, 2010 I suppose its a geometry problem of your model. Thats what I see, its a strange diagonal edge. How did you model this example? . RK Link to comment Share on other sites More sharing options...
JustinTuaylou Posted July 1, 2010 Author Share Posted July 1, 2010 Those images might not be the best examples, but there are no angles, it is just a boolean made from plane and a box, using Cut>Split. The new polygon made by the box is extruded in the negative direction, and then once I try to chamfer the edges around the "hole" that is made I encounter my problem. Link to comment Share on other sites More sharing options...
abmitalia Posted July 1, 2010 Share Posted July 1, 2010 Its the boolean that makes it weard. Take your time and model it differently. Avoid boolean operations when ever you can. Or adjuste the edges in order to have a correct flow and loop. RK Link to comment Share on other sites More sharing options...
bijoy Posted July 2, 2010 Share Posted July 2, 2010 try welding all the vertexes then chamfer it...might be a loose vertex Link to comment Share on other sites More sharing options...
abmitalia Posted July 2, 2010 Share Posted July 2, 2010 The problem with boolean : there are no vertex to weld. You can see that by the diagonal edge. RK Link to comment Share on other sites More sharing options...
FreakyDroid Posted July 2, 2010 Share Posted July 2, 2010 I agree with abmitalia. Its a simple model that can be modeled without booleans. Just start with a box, put an edit poly modifier on top, or just convert it to editable poly, inset the top polygon, adjust the vertices created by the inset, finally extrude the polygon (where the hole should be) in negative direction. You end up with a clean model this way (all quads, no N-gons like in your case), so chamfering any edge(s) won't be a problem. Link to comment Share on other sites More sharing options...
kareemkarawia Posted July 2, 2010 Share Posted July 2, 2010 if you want to make it right ... 1* Inset 2* Extrude 3* Chamfer No problrm??!! Link to comment Share on other sites More sharing options...
