Peter Guthrie HDRIs
Nic H
just bought a handful of these and wanted to share how good they are.
7k spherical, good reflections and high dynamic range.
using these with just a dome light / LWF /phys cam and fiddling with the gamma a tiny bit (lower to .8 or so = more contrast) in the VrayHDR loader gives great results and sharp shadows and lovely colour.
the best HDR's i have used - makes the other stuff in our library a bit redundant. if you are looking for a new lighting solution other than vray/sun/sky give these a try.
i bought some last week, and am hoping for some great results, but i still have a lot to learn about HDRI's (and mental ray).
will probably be digging up some old threads and/or asking a few questions myself.
ah i've been meaning to get these for a while now.
7k spherical isn't particlarly huge - the hdri-locations ones are by far my favourite with 11500x5750, and they just seem to work in mr with very little tweaking, but i'll definitely give these a go.
is there a bundle anywhere, or do you have to buy them singley from 3docean?
Thanks for the plug Nic!
Feel free to ask questions here, I'll do my best to answer them.
Re: resolution, I find that most of the time the resolution is sufficient even for leaving the visible portion of sky as it is (without replacing it in pshop). I used a 1dsmk3 with a sigma 8mm to shoot the skies, as my priority was dynamic range and not resolution. If you are lucky enough to shoot on a day with no wind whatsoever then you might be able to shoot multiple views and stitch them together in order to get a higher res file. As it was even with the sigma 8mm I was capturing 7 shots in just over a second (5 fps on 1dsmk3) and some sequences were unusable due to moving clouds.
Re: bundles, as soon as 3DOcean allow it (if they ever do), i'll offer bundles.
been using them as an all in one lighting/reflection solution with dome light - working very well in conjunction with LWF, res is not much of an issue when only doing 1080 or 720
will post some results when done
For anyone interested, my most used ones from recent projects are:
Frame House - 1725
Square House - 1725
Line House - 1928
Farnsworth House - 1725
Richmond Road - 0743, 1725, 2118
Chelsea Sq Dusk - 2003
Chelsea Sq Day - 1725
Allandale House - 1008
Sail House - 1847
The real beauty of using HDRs though is that you can completely change the lighting and mood of a scene simply by swapping HDR, here are some examples from my Allandale project along with the HDR sky used:
HDR Sky used: 2118
HDR Sky used: 1224
HDR Sky used: 1224
HDR Sky used: 1008
thanks for the ressource,
a question on the licensing though:
if i understand it correct, the standard license of ocean allows one single use of each purchase.
meaning i am allowed to use a bought hrdi for only one project?
cheers,
gordon
  • 5 months later...
