vakis Posted July 5, 2010 Share Posted July 5, 2010 (edited) hi I want to make a render with a size of 3x2 meters, but i dont know how to work with print size wizard, any help? thanks Edited July 5, 2010 by vakis Link to comment Share on other sites More sharing options...
JonRashid Posted July 5, 2010 Share Posted July 5, 2010 you need to know the dpi before you can use the wizard. Once you have this enter dpi and dimensions and it will return a pixel figure for you to apply. Link to comment Share on other sites More sharing options...
Nic H Posted July 5, 2010 Share Posted July 5, 2010 have you thought of taking a photograph of the screen? Link to comment Share on other sites More sharing options...
JonRashid Posted July 5, 2010 Share Posted July 5, 2010 photo of the screen???? Link to comment Share on other sites More sharing options...
Nic H Posted July 5, 2010 Share Posted July 5, 2010 if the original poster cant work out print size wizard or search then it seems (to me) the best option. Link to comment Share on other sites More sharing options...
Andrew1 Posted July 5, 2010 Share Posted July 5, 2010 Hey there, What I usually do is set the render size to 6000 x 8000 and save the render as JPG format it saves the image at true 75 dpi what is great for the size of the render and you can resample the image in PS, I also sometimes go as high as 9000 x 12000 if necessary... Hope this helps..., Andrew Link to comment Share on other sites More sharing options...
Nic H Posted July 5, 2010 Share Posted July 5, 2010 seems like another sensible option. thanks andrew Link to comment Share on other sites More sharing options...
