doniv Posted July 8, 2010 Share Posted July 8, 2010 Hi, This is my first image created with Max + Vray . This is a tutorial from the net, I have tried to replicate the original image (nothing less, nothing more). Your inputs would be appreciated. Thank you Link to comment Share on other sites More sharing options...
karuna.a Posted July 9, 2010 Share Posted July 9, 2010 hi... i cant figureout which is done by you & which is orginal.. mention on the image wud be helpful.... Link to comment Share on other sites More sharing options...
doniv Posted July 9, 2010 Author Share Posted July 9, 2010 Hi, Well Karuna both are my works, I haven't attached the original image. The first is with just the interior lighting and the second with daylight. Thanks Link to comment Share on other sites More sharing options...
karuna.a Posted July 9, 2010 Share Posted July 9, 2010 oh.. ok. well in both the images... Rug/carpet depth is missed. same for art work, adjust a shadow parameter may help. legs of that sofa is diturbed a bit because of some red patches. I like that image with light. keep up good work... cheers.. Link to comment Share on other sites More sharing options...
damu.vfx Posted July 9, 2010 Share Posted July 9, 2010 hi, I think in thefirst image there is no reflections to the floor and other objects.and as karuna said there must be needed some bump(or vray displacement map) to carpet. In cause of second Image you are getting very sharp edges to sun light.try with increasing "size multiplier" in sun parameters and that willl get you some faded sunlight edge. and one more thing is why dont you use some good leather texture which can be obtain in inter net. Over all the images are good.Keep doing the best. best of luck Happy rendering Link to comment Share on other sites More sharing options...
doniv Posted July 9, 2010 Author Share Posted July 9, 2010 Hi Damu, I didn't get the "size multiplier", where will i find it? Link to comment Share on other sites More sharing options...
karuna.a Posted July 10, 2010 Share Posted July 10, 2010 hi Prathiba.. i wanted to learn Vray. can u tell me any institution who is teaching vray or any faculty in bangalore? It will very helpful for me. Thanx... cheers karuna Link to comment Share on other sites More sharing options...
v-tool Posted July 14, 2010 Share Posted July 14, 2010 @karuna.a www.d-s-i-g-n.ru check out this guy, i think u can take online trainings, i didnt follow any of his trainings but i think hes good, Link to comment Share on other sites More sharing options...
karuna.a Posted July 14, 2010 Share Posted July 14, 2010 @karuna.a www.d-s-i-g-n.ru check out this guy, i think u can take online trainings, i didnt follow any of his trainings but i think hes good, Online is pretty expensive also hard to learn.. anyway thanx 4 reply cheers, karuna Link to comment Share on other sites More sharing options...
stormchaser Posted July 15, 2010 Share Posted July 15, 2010 @prathiba : size multiplier is in vray sun option, in case you are using some other light source kindly mention which one and then we might be able to tell you how to get soft shadows (usually in shadow map option for other light sources) in the first image the table seems to be floating, also the first one is supposed to be lighted with artificial light and second one with sunlight but the lamp is on in second one and off in the first one. floor needs reflection. and the walls kinda look empty, add some artificial light fixtures, a spot light on top of painting would be nice. @karuna : id suggest learn it yourself instead of going to a institute, there are plenty of free tutorials available online, you can learn almost everything for free. specially when you want to learn just vray, its not that complicated. Link to comment Share on other sites More sharing options...
karuna.a Posted July 16, 2010 Share Posted July 16, 2010 @saji: hi thanx for ur suggestion... Pls suggest some links if u have.... cheers, karuna Link to comment Share on other sites More sharing options...
stormchaser Posted July 16, 2010 Share Posted July 16, 2010 http://www.youtube.com/watch?v=uja6aoggJ3g check this tutorial series, its pretty basic, im sure there are better tutorials out there but its not a bad starting point. just check the various tutorials uploaded on you tube. if you want to set up lights in an interior scene, check for the tutorial that shows in the links to other video about lighting a room. Link to comment Share on other sites More sharing options...
doniv Posted July 16, 2010 Author Share Posted July 16, 2010 Hey Guys Thank you all for taking the time out to give your comments I ll to incorporate all those pointers provided by you guys and am sure to come up with a few more doubts but I guess I will always have some one to help me out here. Sajid - that was very thoughtful of you to provide those links, it does help beginners' like me. Thank you Link to comment Share on other sites More sharing options...
karuna.a Posted July 17, 2010 Share Posted July 17, 2010 http://www.youtube.com/watch?v=uja6aoggJ3g check this tutorial series, its pretty basic, im sure there are better tutorials out there but its not a bad starting point. just check the various tutorials uploaded on you tube. if you want to set up lights in an interior scene, check for the tutorial that shows in the links to other video about lighting a room. @Sajid : Thanx man it wud be really useful & helpful for us.Hope fully i will be back with good rendering & loads of doubts... cheers man... Link to comment Share on other sites More sharing options...
