Cesar Posted July 8, 2010 Share Posted July 8, 2010 (edited) Hello To everyone Someone knows if is possible to keep revit material names using the file link manager and the fbx format? let me explain it. In revit 2011 i had a material with an specific name, for example “concrete column” and its render appearance is based in the autodesk library “Flat - Gray 1” when i transfer the file to 3ds max, using the file link manager, that material transfer with the name “Flat - Grey 1” and i would like to transfer that material with his original name “concrete column”, funny because the previous versions of revit or max, the materials transfer with they respective names. this is really annoying, because in our office, have several materials, but all are based in the same render appearance, so transfer like the were the same. Edited July 8, 2010 by Cesar Link to comment Share on other sites More sharing options...
Justin Hunt Posted July 8, 2010 Share Posted July 8, 2010 the latest hotfix addresses some issues with FBX materials and their textures, not sure if it will fix what your are after though Try installing the latest FBX installers too jhv Link to comment Share on other sites More sharing options...
Cesar Posted July 9, 2010 Author Share Posted July 9, 2010 Yes, i Already upgrade both (3ds max hotfix and the fbx plugin) and the situation persists Link to comment Share on other sites More sharing options...
pfbreton Posted July 19, 2010 Share Posted July 19, 2010 Yes, i Already upgrade both (3ds max hotfix and the fbx plugin) and the situation persists Hi Cesar! can you strip down the revit model in a way that its file size gets small and provide us a download link to get the model? We will have a look at it. Ideally, zip up the revit model as well as the fbx file that creates trouble for you. Thanks! Link to comment Share on other sites More sharing options...
Cesar Posted August 12, 2010 Author Share Posted August 12, 2010 Hi Pierre, thanks for your support, I can still send you the file? Link to comment Share on other sites More sharing options...
