Devin Johnston Posted July 9, 2010 Share Posted July 9, 2010 Like it says I'd like my default library location to be a network drive, how do I change this? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 9, 2010 Share Posted July 9, 2010 (edited) WHAT I DESCRIBED BELOW DOES NOT WORK FOR MAX 2011 I use.... Customize - Configure User Paths. Then I re-path to where my assets are on the network. One thing to note though, I don't work with project folders. I am not sure if working with project folders would alter this process. For example... Images = \\group\hok\SF\Resources\Render Farm\Textures Import = \\group\hok\SF\Resources\Render Farm\+ UNC Paths Photometric = \\group\hok\SF\Resources\Render Farm\Photometric Materials = \\group\hok\SF\Resources\Render Farm\Materials Scenes = \\group\hok\SF\Resources\Render Farm\+ UNC Paths Etc... Etc... You will notice I keep a directory called UNC Paths. This directory has windows shortcuts to where my various projects live on the server. I do this because we try and keep all project files located with the architecture files for backup and organization. Keeping a directory of shortcuts allows me to hit file open, and then be presented with a list of projects that only require 1 click to access rather than sorting through project directories. Not sure if this is what you meant or not. Edited July 9, 2010 by Crazy Homeless Guy Link to comment Share on other sites More sharing options...
Devin Johnston Posted July 9, 2010 Author Share Posted July 9, 2010 What I want is when I select "Open Material Library" from the Material/Map Browser for it to open up to the network location where all the material libraries I've created are. I tried changing the Materials location under Configure User Paths/File I/O to that location but it's not working. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 9, 2010 Share Posted July 9, 2010 Hmmm... Mine currently does that with the process I described above. I have my materials pathed to a location on the server. When I hit open material library, it opens into the server directory. Likewise, when I go to assign a texture, it opens to the texture library on the server. Link to comment Share on other sites More sharing options...
Devin Johnston Posted July 9, 2010 Author Share Posted July 9, 2010 I'm using Max 2011 how about you? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 9, 2010 Share Posted July 9, 2010 2010, we havent switched yet. I just tried it on 2011 and I appear to be having the same problem. When I try to open a material library it picks some random directory. Link to comment Share on other sites More sharing options...
Devin Johnston Posted July 9, 2010 Author Share Posted July 9, 2010 Exactly! Link to comment Share on other sites More sharing options...
JamesL Posted July 9, 2010 Share Posted July 9, 2010 Don't know about changing the default path but the best workaround is just create a shortcut in the folders it opens into... I've created shortcuts in most of autodesks default folders (maps, material library, import etc)...I might be stating the obvious! Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted July 15, 2010 Share Posted July 15, 2010 best utility ever. seriously. http://www.codesector.com/directfolders.php Link to comment Share on other sites More sharing options...
Devin Johnston Posted July 15, 2010 Author Share Posted July 15, 2010 I don't think that will help with the problem we're having. Link to comment Share on other sites More sharing options...
-MerlyN- Posted July 15, 2010 Share Posted July 15, 2010 Well, Win7 has that built in in its library folder system... Link to comment Share on other sites More sharing options...
