insert 3d objet in image
zewanil
Hi Guys
i am wondering how I will render my object so it will be perfectly align when i will insert it in a 2d image ...
is there any tutorials ..
i put a screenview to show you how i try to make it correct .. but it seems it never perfectly align
thanks for helping
P
the models looks bent you need to rotate so it's straight it and in the front viewport select the move it down to the floor are they all images in that photos or have you modeled some of them? if they are models you could always use the align tool and align your model to the others.
I wouldn't necessarily bother to use the camera match tool. It would be useful to roughly model the walls that make up the corner if you have some dimensions as this will help with alignment and scale. You also definitely need to use a wider field of view for your camera. Just play around with the camera position and focal length till you get that corner lined up and the perspective looking correct.
