Grass: Photoshop Method?
braddewald
Photoshop also has a grassy looking brush. You can use this with either the clone tool or by painting in a layer mask to give a more realistic edge to your grass areas. I use this method a lot to make displaced grass look more natural or to make non-displaced grass look 3d. By adjusting the scattering and random rotation etc. you can get good results.
I use grass photos in most exterior renders I do. I will also combine it with displacement though and as a point of note I tend to 'overlay' the displaced grass over the field photo that I have used, rather than the other way round. I find you retain more accurate GI lighting and shadows when you apply the rendered grass onto to the photo, rather than applying the photo onto the rendered grass... if you get me... eg:
http://forums.cgarchitect.com/40587-east-kilbride-residential-2.html
go to google, search for images with the large size checked and type in golf course.
Should give you many images to pick from with different lighting conditions... then just comp it in.
[ATTACH=CONFIG]38110[/ATTACH][ATTACH=CONFIG]38111[/ATTACH]
  • 3 weeks later...
