adbent Posted July 17, 2010 Share Posted July 17, 2010 Studio/Institution: Palace ConsultingGenre: Residential InteriorSoftware: Autocad, 3dmax 2009 with vrayDescription: This is my very first time in interior rendering..rendered in max with vray..I will be thankful to drop your comments guys for my improvement on this field...what are your suggestions to improve this work of mine... best regards, adbent Link to comment Share on other sites More sharing options...
Jason Matthews Posted July 18, 2010 Share Posted July 18, 2010 Great start! For the most part, the materials are working. I think having a camera angle directly perpendicular with your subject tends to flatten the image. Try changing the viewing angle. The entire image looks a bit washed out and not much color in the lighting. I think your lights may be set too high. Are you using photometric lights? If not you should definitly look into it. The wall to the left has too much bump on it. Keep going. This could be a great image. Link to comment Share on other sites More sharing options...
adbent Posted July 18, 2010 Author Share Posted July 18, 2010 @saturn: wow thank you so much for your comments, i really appreciate it..i am using vraysun,vraycam,3vray lights and 1 ies file..all your comments are noted sir and i'll work on it.. thank you so much.. Link to comment Share on other sites More sharing options...
