jophus14 Posted July 21, 2010 Share Posted July 21, 2010 Attached are two pics of rock faces made of limestone and I would appreciate some suggestions on how to create similar rock structures. I could use a VrayDisplacement but since the pattern is so irregular I'm not sure how that would work. I think poly-modelling this would be brutal since the rock will be pretty long in length (almost 300 feet) and will be seen from a slight aerial view. I was checking out some tutorials but since these are layered rocks those tutorials wouldn't help. I would appreciate any advice. Thank you all. Link to comment Share on other sites More sharing options...
JonRashid Posted July 21, 2010 Share Posted July 21, 2010 I am not sure if you have access to mudbox. If you have you can create a high res version and use a bump map of the bricks as a brush. Once done you can generate normal maps etc from this and re-apply to your low res version. this will allow you to create an organic feel to your cliffs. Link to comment Share on other sites More sharing options...
jophus14 Posted July 21, 2010 Author Share Posted July 21, 2010 I don't have Mudbox but it sure does look cool. I found a pretty good texture on CGtextures and I created a reflection and displacement map out of it. I placed those maps on the geometry added modifiers and then copied that geometry a few times and adjusted the shape so each layer is different. It looks okay but I am still interested in hearing other suggestions. Thanks. Link to comment Share on other sites More sharing options...
pipjor Posted July 21, 2010 Share Posted July 21, 2010 looks like Starved Rock in IL?? Link to comment Share on other sites More sharing options...
jophus14 Posted July 22, 2010 Author Share Posted July 22, 2010 I was looking at Starved Rock here in Illinois for references but this is actually from Wisconsin Dells along the Wisconsin river. I think Starved Rock is sandstone and this is limestone. I might be wrong about that though. Link to comment Share on other sites More sharing options...
