karolisbilz@yahoo.com Posted July 21, 2010 Share Posted July 21, 2010 please kind ppl help figure out what kind of weird stuff is in my render....i mean the grey'ish plots here and there on the ground....i'm using max 2011 design and mental ray and used forest lite for trees....everything went well and then today i started doing some final touches and making some test renders ...and i see those gray awefull things....tried merging everything into new scene....didn't help much....tried to get rid of trees and all the ground plane nether did that help...pls help me get around this Link to comment Share on other sites More sharing options...
Matt McDonald Posted July 21, 2010 Share Posted July 21, 2010 it kind of looks like coplanar faces. you don't have two ground planes in there do you? are you sure that the geometry of your ground plane is clean? What happens if you hide the ground plane and re-render then hide everything but the ground plane. Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 22, 2010 Author Share Posted July 22, 2010 I don't know if it's clean....it supose to be clean....it was in Revit. and i think that's the problem. cause all geometry mamde in revit acts weird at least for me. i made new ground plane in max put on the same texture and it seem to be gone, BUT i small plots of the same "s**t" appeared on the building itself and would really hate to remake the model, cause i've got no time for this. PLS some1 help me with this Link to comment Share on other sites More sharing options...
Matt McDonald Posted July 22, 2010 Share Posted July 22, 2010 Despite what the Autodesk marketing material may say Revit into Max isn't such a smooth transition. Search here for Revit to Max, there have been lots of threads on the subject. You'll be able to find some tips that may help you out. Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 22, 2010 Author Share Posted July 22, 2010 damn it....i'm searching for similar type of problem that some1 had but with no luck....hope dies last lol fingers crossed Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 22, 2010 Author Share Posted July 22, 2010 searching for similar problem....no luck...baaaaad Link to comment Share on other sites More sharing options...
karolisbilz@yahoo.com Posted July 22, 2010 Author Share Posted July 22, 2010 and the most weird thing about it is that i get these type of artifacts only from further distances.....when it's close everything seems to be fine.....maybe that will help you with helping me Link to comment Share on other sites More sharing options...
