Best way to model these shapes?
Playdo
looks like some sort of torus knot and spherify modifier used...give it a try.. Do you need the exact style showed in the pics ? if yes then prolly you can loft and then scale them for different copies
good luck
Meher
I'd have thought they'd both be lofted, thought I'd throw it open to other suggestions. I'm not sure how you'd get the matching offset paths though.
BTW I don't understand how you'd get close by using the shell mod?
To me the first one is a "lets just add modifiers to an extended primitive and see what happens". I don't think there is a single bit of intentional modelling in it. To replicate it would be difficult.
For the second one i'd start with a spline to make my path, add the sweep modifier and take it from there. A poly mod could be used with a ring selection to cut your segments through and also to tweek the shape but it would also pose a few difficulties in the process. The obvious is to finish with a turbo smooth.
