New heuristic method in Shader Utilities
thorsten hartmann
Hi Guys,
i have a new heuristic algorithm to find the best Sample Amount, Fast Interpolation Grid + Sample Amount and Reflection/Refraction Depth for each Material. At last i have found some little Bugs and fixed.
Update nach SU Build(20100725)
commercial Projects with Shader Utilities Pro:
VAM: http://www.infinity-vision.de/ShaderUtilities/eng/testrendering_vam.htm
Attic: http://www.infinity-vision.de/ShaderUtilities/eng/testrendering_sessel.htm
Example Metall Dragon:
non optimize: All different Metals have only 8 Reflections Sample, and the glossy reflections look all the same. At last you see grainy.
optimize: The hole scene with only one mouse click. All different Metals look different glossy reflections, and without grainy.
look here for 4000x2309 Resolution: http://www.infinity-vision.de/ShaderUtilities/eng/testrendering_dragon.htm
have fun!
mfg
hot chip
Edited by thorsten hartmann
  • 1 month later...
hi Guys,
It give a update.
Changes for Build 20100904 are:
- Reflection and refraction now use only one Glossy Sample Curve
- The Force Sample value has been removed from the UI
- The Contour Simple Shader has been added to all TH-Materials
- Shader Utilities can now be used to set up the Contour Shader
- The Contour Shader can now be added/removed/set up for every Arch&Design material in the scene
Tutorial "the mental ray Workflow" in english comming soon...
have fun!
mfg
hot chip
  • 3 weeks later...
  • 2 weeks later...
