Malik1 Posted August 8, 2010 Share Posted August 8, 2010 Hey guys, First post / long time lurker. I've spent way to much time trying to figure this one out, any help would be sweeeeet. I've been a long time 3DS max and Maxwell Render user but recently I have started to deal with Revit dwgs. Ive imoprted ACIS solids and Polymesh DWGs from the original Revit file and here is what happens:(fyi I know all about the fbx option am Im trying to figure out the dwg possibilities) 1: render without doing anything. Result= certain objects are missing(some exterior walls)Example- 2: apply the defualt Maxwell material to all objects.Result= same objects are missingExample- 3: Import as one entity(looks fine) but apply a default maxwell material and.... Result= the whole model turns into flats planes.Example- Ive heard about people exporting revit models via DWG to autcad and doing somthing to the model before import to MAX...I'd like to hear how that works. Basically we have 3 export options from revit and 20 import options in Max + all the maxwell settings.....i'm a little lost. What am I missing here? What is most appropiate workflow with Revit - Max - Maxwell?? Thanks, Link to comment Share on other sites More sharing options...
Malik1 Posted August 8, 2010 Author Share Posted August 8, 2010 OK, this doesn't seem to be an issue with maxwell because the import from my ADt models are fine. All the geometery is correct etc. there has to be something going on with the DWG from Revit. Link to comment Share on other sites More sharing options...
Malik1 Posted August 9, 2010 Author Share Posted August 9, 2010 Success! It was a maxwell issue(option), when exporting from Revit some objects are converted into instances so you have to make sure to uncheck the "use instances" box in the render options.see pic. [ATTACH=CONFIG]38564[/ATTACH] wow! I hope someone reads this before going through I did to figure that out. All in the game I guess. LTR, M Link to comment Share on other sites More sharing options...
