mskin Posted August 12, 2010 Share Posted August 12, 2010 i just fresh installed max design 2010. Upon launching program for the first time the program "unexpectedly quits". of, course, after the third attempt it is no longer "unexpected". any ideas what could be causing this? i have run max 2010 on this machine successfully before - prior to reinstalling OS (XP PRO SP 3 - QUAD CORE - 2GIGS RAM) i tried reinstalling (after unistalling) and launching it as a different user. this is very bad for me. thanks Link to comment Share on other sites More sharing options...
Cyberstyle Posted August 12, 2010 Share Posted August 12, 2010 I had the same issue here at work. Installed fine, try to open but Max quits before fully loading up a few times, then nothing at all. I had to un-install all the antivirus software, turn off the firewalls, install Max and then re-install the virus software. Then it worked fine. A pain in the ass too, because it was on 6 seperate machines. 2010 was the only version I had problems with. Link to comment Share on other sites More sharing options...
mskin Posted August 12, 2010 Author Share Posted August 12, 2010 (edited) oh no. what anti virus out of curiosity? - and did you try just shutting it down before uninstalling it? Edited August 12, 2010 by mskin Link to comment Share on other sites More sharing options...
Cyberstyle Posted August 13, 2010 Share Posted August 13, 2010 We have Symantec AV. Yes tried just shutting it down - that's what I would normaly do, but it did not work. Tried to create exceptions and every option with the AV but each step gave the same result. Removing the AV was the only way I could get Max to run after install. Members posted up an install issue with Max 2010 and Symatec and a 'solution' was on the Autodesk Area forum but it did not work for me. I had to completely remove it first. Link to comment Share on other sites More sharing options...
mskin Posted August 13, 2010 Author Share Posted August 13, 2010 thanks for your help. i un installed norton av, reinstalled max... but still no go. any further ideas? Link to comment Share on other sites More sharing options...
Cyberstyle Posted August 13, 2010 Share Posted August 13, 2010 Sorry Herbert, the process I used as I mentioned got me going without a problem. I'm not sure what else it could be. I don't know what your setup is like but I think it also had to be installed under the administrators account too. We have roaming profiles on our network which may have been part of the problem? Link to comment Share on other sites More sharing options...
alrawli Posted August 13, 2010 Share Posted August 13, 2010 Recently got 2 new machines with Dual X5650 processors so 24 cores in total, max 10 has a problem recognising these or at least the mental ray installer does. If you change the name of the mentalray.dlo file it doesnt load on startup and lets max run. I realise this isnt a fix if you use mental ray but if you use Vray it works fine. Link to comment Share on other sites More sharing options...
zhak Posted August 13, 2010 Share Posted August 13, 2010 hi every one here... i have olso a problem with my 3d max and i really don't how to solve it... my problem is that every time that i open 3d max it's shows thise message: dll"c:\program files\autodesk\3ds max 2010\ stplugs\fbmax.dlu...after that i press ok again and it shows another message ...error loading dlls faild to instailize ERROR CODE 193...and then i press again enter and i open the program... olso i whant to istill my v-ray and when i go to rendering-rendering set up-assign renderer * production i choose v-ray and in v-ray cartele its empty... what can i do ... will some body help me? PLEASSSSSEEEE Link to comment Share on other sites More sharing options...
