zewanil Posted August 13, 2010 Share Posted August 13, 2010 Hello there i really dont no whats going on but when i render my scene there is those spot on it ..( i attach some render region so you can see ) is there a way i can remove it ? i have try so many way but i cant ... thanks a lot for helping P. Link to comment Share on other sites More sharing options...
berrys Posted August 13, 2010 Share Posted August 13, 2010 select your sun, go to the modify panel and check the invisible option Link to comment Share on other sites More sharing options...
zewanil Posted August 13, 2010 Author Share Posted August 13, 2010 thanks for the time but there is no sun in my scene ... just some vray light on the window Link to comment Share on other sites More sharing options...
azeta3d Posted August 13, 2010 Share Posted August 13, 2010 hey there, if its not the sun its an error on the irradiance map, try rising the seetings of both ir and vraylights, hope it works, cheers! Link to comment Share on other sites More sharing options...
njoco2 Posted August 13, 2010 Share Posted August 13, 2010 Make sure that all of the materials in the scene are vray materials. Sometimes Standard materials can produce these white spots when rendered with vray. Cheers. Link to comment Share on other sites More sharing options...
zewanil Posted August 13, 2010 Author Share Posted August 13, 2010 didnt solve the problem very weird ... thanks for helping Link to comment Share on other sites More sharing options...
azeta3d Posted August 13, 2010 Share Posted August 13, 2010 damn, that happened once to me long ago, i cant remember how i solved it. Do you have caustics in the scene?? if you do try turning them off. If not, just to check, try to check if your model is not really far away from the 0,0,0 coordinate. Link to comment Share on other sites More sharing options...
