Three D Posted August 17, 2010 Share Posted August 17, 2010 (edited) Hi. Can anybody tell me how to adjust the colour of the shadows cast by individual objects. I'm doing a shadow study and I'd like to colour code shadows for eaves and ridges of roofs to see what shadows each are casting. I'm using a daylight system with VRaySun. Any help would be very much appreciated. Thanks. Edited August 17, 2010 by Three D Link to comment Share on other sites More sharing options...
mu_688687 Posted August 17, 2010 Share Posted August 17, 2010 If you want to get different color shadow from different-2 object than adjust it from V-ray property color. Link to comment Share on other sites More sharing options...
Three D Posted August 17, 2010 Author Share Posted August 17, 2010 If you want to get different color shadow from different-2 object than adjust it from V-ray property color. Thanks but the shadow colour option in the Vray Object properties is only for mattes objects. I did try it and it didn't work. Link to comment Share on other sites More sharing options...
JonRashid Posted August 17, 2010 Share Posted August 17, 2010 You could use the include and exclude part of your light parameters. You might have to mess about with the objects receiving the shadows to ensure they are not flooded out by all the lights you use. You then modify the shadow colour of each individual light. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 17, 2010 Share Posted August 17, 2010 (edited) I would apply a VrayOverrideMtl to each object's material and put colored glass in the shadow override slot..... then just give each material a different refraction color to create your color coded shadows. [ATTACH]38726[/ATTACH] Edited August 17, 2010 by BrianKitts Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 17, 2010 Share Posted August 17, 2010 Good solution Brian. The immediate thing that came to mind for me requires a two pass rendering setup utilizing the VrayMatteShadow render element, and controlling what can cast shadows. Link to comment Share on other sites More sharing options...
Three D Posted August 18, 2010 Author Share Posted August 18, 2010 Thanks for all the help guys. The VrayOverrideMtl seems like the quickest method for me needs but I'll mess around with both options. Link to comment Share on other sites More sharing options...
