tecton3d Posted August 19, 2010 Share Posted August 19, 2010 Does anyone know of a Max plugin/tool/modifier that resembles Form-Z's "CONTOUR" tool? It allows for a single object to be slice according to reference plane (x,y,z, arbitrary) , and numeric increment. It would allow for an effect like this: (see image 1, 10) http://inhabitat.com/2010/08/10/big-unveils-gigantic-cube-building-with-a-rooftop-park/ted-cube-building/?extend=1 the idea is to model the mass of the cube, subtract the spiral from that, then use this "contour" tool to establish the horizontal levels. thanks. Link to comment Share on other sites More sharing options...
Jose Negrete Posted October 5, 2010 Share Posted October 5, 2010 you can use the section tool in the create shapes menu. that will generate a spline wherever you place the cutting plan. you can then take this spline and extrude it to get the floor slabs. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted October 5, 2010 Share Posted October 5, 2010 You can use shift-move cloning to make a bunch of evenly spaced copies quickly. I found that directly converting the section object to a spline gave me open curves. Using the section object's Create Spline button gave closed. Closed is good if you are making floor slabs. Link to comment Share on other sites More sharing options...
