Christiansltd Posted August 24, 2010 Share Posted August 24, 2010 Hi i have always been lead to belive that you should use nvida quadro spec graphics cards for autodesk applications for stability and performance but have recently heard lots of talk about geforce cards that are cuda enabled are exactly the same apart from drivers, i even heard from a trusted source that an nvidia rep said the gtx cards are exactly the same as the quadro cards and you would be stupid to spend the extra....... I dont mind spending the extra and the new Quadro Fx 4000 @ 2Gb seems a really good price for the workstations however if the cheaper non commercial spec cards really do work fine then there is to be a saving made and you could get a 4gb card for roughly the same price.. Very confused, any advice would be greatly appreciated Link to comment Share on other sites More sharing options...
Jeff Mottle Posted August 24, 2010 Share Posted August 24, 2010 This should help: http://www.cgarchitect.com/news/Reviews/Review076_1.asp If you get the newer GTX cards and the latest (as of several weeks ago) Quadro cards that all use the new Fermi chip architecture, however for CUDA related apps for rendering, the more memory and stream processors you have the faster and larger scenes you will be able to render. For strictly viewport performance, read the review above for more detailed information. Link to comment Share on other sites More sharing options...
AJLynn Posted August 25, 2010 Share Posted August 25, 2010 Do you use a CUDA or OpenCL app or are you just looking for something to power your viewports? Link to comment Share on other sites More sharing options...
Christiansltd Posted August 25, 2010 Author Share Posted August 25, 2010 I need it for viewport display, its for Vue 8.5, 3DS Max & Autocad Civil 3D, we do landscape and civil vis so data sets are quite big and the currentQuadro FX 4600 we have are struggling a bit. Link to comment Share on other sites More sharing options...
AJLynn Posted August 25, 2010 Share Posted August 25, 2010 Well, a Quadro 4000 should certainly give you a boost. Link to comment Share on other sites More sharing options...
Cesar R Posted September 9, 2010 Share Posted September 9, 2010 Hey guys, I would like to build a machine to render using Octane or similar real time engines. I noticed the on the octane render site, some people express that their GeForce nvidia with a 1.5GB of ram work great with their engine. What is the main difference with the GeForce line versus the Quadro line. It seem both have comparable ram amounts and Geforce is certainly much more economic. Link to comment Share on other sites More sharing options...
AJLynn Posted September 9, 2010 Share Posted September 9, 2010 Not much, for Octane, as far as I can tell so far. It would certainly appear that unless there are further changes to the software that differentiate the lines, Geforce 4-series cards are the current price/performance leaders for this. Link to comment Share on other sites More sharing options...
Cesar R Posted September 10, 2010 Share Posted September 10, 2010 What is the difference between card lines Andrew, can you reffer me to some link maybe? I just went back to the nvidia site and noticed both lines go up pretty high on cores. Link to comment Share on other sites More sharing options...
AJLynn Posted September 10, 2010 Share Posted September 10, 2010 http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_400_Series Link to comment Share on other sites More sharing options...
Christiansltd Posted September 15, 2010 Author Share Posted September 15, 2010 Right think i am getting somewhere at last i have narrowed my options to: Quadro 4000 Ati firepro 7800 Or at a third the price a gtx 460 2 GB. I will be using this for large projects using acad civil 3d, 3ds max & vue 8.5, currently i mainly get issues when using Civil 3D in 3D viewport and when trying to pan around. What would be the advantage of getting a pro card over the gtx ? I look forward to your response as always, Cheers CJ Link to comment Share on other sites More sharing options...
Christiansltd Posted September 18, 2010 Author Share Posted September 18, 2010 Hi i have decided to try the Nvidia GTX 460 2GB (Palit) Seems a good card and just giving it a try in Civil 3D with some heavy data. Is there any specific or special drivers available that i should be downloading or just the basic ones from nvidia ? Thanks in advance Link to comment Share on other sites More sharing options...
Christiansltd Posted September 18, 2010 Author Share Posted September 18, 2010 Hi trying out the gtx 460 2GB i am coming up with a few issues. It seems fairly ok until you try to use the orbit tool, see the second picture, has anybody esle encountered this, what you can see is a 3d topo survey of quite a small site. [ATTACH=CONFIG]39170[/ATTACH] This image shows what happens when usige image orbit tool [ATTACH=CONFIG]39169[/ATTACH] Link to comment Share on other sites More sharing options...
Christiansltd Posted September 22, 2010 Author Share Posted September 22, 2010 Hi, still not resolved the above issue, is this an inconpatability issue, does anybody have the same issue ? Link to comment Share on other sites More sharing options...
AJLynn Posted September 22, 2010 Share Posted September 22, 2010 Do you have the latest drivers from the web site? The 460 has a new core (GF104) and usually that means you get some driver bugs. Link to comment Share on other sites More sharing options...
Cesar R Posted September 23, 2010 Share Posted September 23, 2010 Is there a table on the nvidia site which point out which core is in each card? Link to comment Share on other sites More sharing options...
AJLynn Posted September 23, 2010 Share Posted September 23, 2010 http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units Link to comment Share on other sites More sharing options...
Professor Posted September 28, 2010 Share Posted September 28, 2010 Christiansltd said: Hi, still not resolved the above issue, is this an inconpatability issue, does anybody have the same issue ? Looks like it is turning objects into boxes due to the fps being to low. There is a setting where you can override this or adjust the graphic view for a particular fps. I know you just bought a screaming video card and shouldn't have this issue, but if that is what is happening, then just wanted to mention a possible work around. Link to comment Share on other sites More sharing options...
Christiansltd Posted September 29, 2010 Author Share Posted September 29, 2010 Excellent, thanks for that i will give it a try. Link to comment Share on other sites More sharing options...
Jock Posted September 29, 2010 Share Posted September 29, 2010 I know max has a similar response if the scene is a bit too heavy, where it will turn all the objects into bounding boxes while you pan. I take it, it goes back to normal once youve finished panning? Link to comment Share on other sites More sharing options...
