carlangas Posted June 29, 2004 Share Posted June 29, 2004 Hi all, Im having a little trouble with dims. I am copying and pasting an elevation from 2 different dwgs with different UCS´s, when I paste my selection the dimensions rotate to the WCS of the target dwg. Ive tried to changing the ucs´s to match either dwg and using just the WCS but the dims just keep rotating (the text in the dim). I hope im being clear. Is there a variable that I need to turn on? please help!! Thanks Link to comment Share on other sites More sharing options...
TheAllusionisst Posted June 29, 2004 Share Posted June 29, 2004 Hmmm, I am not certain about a variable that effects dims except perhpas, "ucsfollow". You may play with it so that the ucs is or isn't rotated to your new elevation. Link to comment Share on other sites More sharing options...
carlangas Posted June 29, 2004 Author Share Posted June 29, 2004 the thing is that the text in the dimensions are allways oriented to the world ucs regardless if I rotate the ucs or not. I cant figure out how to avoid this cs Link to comment Share on other sites More sharing options...
Onslaught Posted June 29, 2004 Share Posted June 29, 2004 can you post a screen shot, can't quite understand. You might just have to turn "DIMTIH & DIMTOH" "OFF". Link to comment Share on other sites More sharing options...
carlangas Posted June 29, 2004 Author Share Posted June 29, 2004 I hope this illustrates the problem Link to comment Share on other sites More sharing options...
carlangas Posted June 29, 2004 Author Share Posted June 29, 2004 in the ¨after pasting¨pic, the text has changed orientation to match that of the WCS and that is what im trying to avoid. Link to comment Share on other sites More sharing options...
Rusty Posted June 30, 2004 Share Posted June 30, 2004 Set up a new (temporary) ucs while you paste in the dimensions. Link to comment Share on other sites More sharing options...
