Thion Posted August 26, 2010 Share Posted August 26, 2010 I'm working on a script that automatically sends a scene to our backburner server, including 3 networkjobs (photon map, FG map and the actual render - all in mentalRay) with split scanline rendering. I'm using the commandline rendering technique, and that can pretty much set everything I need, except dependencies. I've tried working around the issue by attaching a postrenderscript in the FGmap-file that should unsuspend the initially suspended final render file. That postrenderscript is triggered, and it executes all the code, except the one line: mJob.Resume() The script executes the line, but when I look at the queue monitor, the job is still suspended. Is there a problem with unsuspending jobs through the netrender interface in max2011? Or alternatively, has anyone else encountered a similar problem and found another workaround? Thanks in advance, Davy. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted August 26, 2010 Share Posted August 26, 2010 thats actually a major problem, theres a couple threads on that in the cgtalk maxscript forum, search for BBSetDependency.py by Keith Morrison / KramSurfer Its not very straightforward, but its possible.. its also possible to convert the python script (after you edit it) to an exe that you can call from the commandline. Link to comment Share on other sites More sharing options...
Thion Posted August 26, 2010 Author Share Posted August 26, 2010 Thanks for the reply. I haven't done any programming in python before, so I have no idea what's possible. I think the company would prefer sticking with MAXscript though. I'll take a look at the python script nonetheless and see if I can come up with a solution. If someone knows of a MAXscript solution, I'd be happy to hear about it Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted August 26, 2010 Share Posted August 26, 2010 I'm sure it could be translated somewhat, its just a bit of an odd process.. requires archiving the job, editing the xml, and un-archiving it on the server i believe. I haven't really looked into it much, I've been using LPM to do something similar for a while now. Link to comment Share on other sites More sharing options...
