farrokh Posted August 28, 2010 Share Posted August 28, 2010 hi I'm going to use rocketbox library but my scene scale is smaller than real dimensions. so i tried to resize them to fit my scene but I couldn't able! any one know the solution? Link to comment Share on other sites More sharing options...
farrokh Posted August 28, 2010 Author Share Posted August 28, 2010 after posting this request I found the way to achieve this. I used mesher object to catch animation. but I'm using vray and planing to use vray proxy so if there any other solution I would be pleased to learn. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 30, 2010 Share Posted August 30, 2010 You could save the animation out to a point cache file. There's no real need to save out to a proxy I don't think, as the meshes aren't particularly poly-heavy. Link to comment Share on other sites More sharing options...
olumaiye Posted February 3, 2011 Share Posted February 3, 2011 hi, Got rocket box pack to but the issue is that wen i import the .anim file, my model gets screwed badly. I use maya though, bt i need help real bad pls Link to comment Share on other sites More sharing options...
