jam_ed Posted August 29, 2010 Share Posted August 29, 2010 I've been trying to place some realistic photometric ies lights with web distribution. Somehow I'm having trouble determining the light intensity of these lights. When I place them on a average room I have to set up to 6000 candellas till i finally see a bit light. This makes it hard for me to get a realistic representation. My scenes have a realtime scale (in milimetres) and are a nighttime outside scene. Can someone give me some advice on getting them to work properly? Link to comment Share on other sites More sharing options...
jophus14 Posted August 30, 2010 Share Posted August 30, 2010 You may have to raise the "Intensity" multiplier depending the IES that you are using and the size of the room. Use less IES lights in your space and raise the multiplier up. I have had some lights with a multiplier of 50,000. Hope this helps. Link to comment Share on other sites More sharing options...
odouble Posted August 30, 2010 Share Posted August 30, 2010 edsondc said: I've been trying to place some realistic photometric ies lights with web distribution. Somehow I'm having trouble determining the light intensity of these lights. When I place them on a average room I have to set up to 6000 candellas till i finally see a bit light. This makes it hard for me to get a realistic representation. My scenes have a realtime scale (in milimetres) and are a nighttime outside scene. Can someone give me some advice on getting them to work properly? I am guessing that you are using the default gamma settings in max. If you change them to 1.8 or 2.2 your lights should be more predictable. Link to comment Share on other sites More sharing options...
ramy Posted September 27, 2010 Share Posted September 27, 2010 This seems to obvious, but did you check your exposure settings? Link to comment Share on other sites More sharing options...
jam_ed Posted September 28, 2010 Author Share Posted September 28, 2010 Thanks for the responses. Ofcourse you can always adjust the gamma/exposure/light intensity. But I thought the idea of downloading ies profiles was to get a realistic fixture setting out of the box. can you share the way you implement these profiles in your scenes?? Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted September 29, 2010 Share Posted September 29, 2010 Walk into a dim room from the bright outside. How come you can't see anything? Because exposure is an integral part of reality. Gamma should be set up for correct light behaviour in order to get correct results. Changing light intensity is not correct. Link to comment Share on other sites More sharing options...
