nonius3d Posted May 27, 2011 Share Posted May 27, 2011 Its an 8 cpu intel i7 machine, with 12gigs of ram. Speed depends on so many factors that it differs every time. But I am really satisfied. Using nodes speeds up things quite a bit too. gr. sven Link to comment Share on other sites More sharing options...
SreckoM Posted May 27, 2011 Share Posted May 27, 2011 So you are rendering only on that machine? Or you have small render farm? I have same machine and last time I did test doing 3K interior render takes more than 24h to get descent noise free render. Link to comment Share on other sites More sharing options...
Mario Pende Posted May 30, 2011 Share Posted May 30, 2011 I use maxwell and Octane in production and it's okay to use. Maxwell if I have some time for the rendering and Octane for small animations (in unbiased mode). Hi! I see you use Octane. Can it be used for rendering exteriors of small residential buldings? I see they say that you have a memory limit of what you can render... Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 10, 2011 Share Posted August 10, 2011 Maxwell is great for those who aren't in a moderate to heave professional production environment. That's not to say it's not a professional product but it's biggest handicap will always be its speed. Some people believe that the speed issue isn't really that big of a deal because computers keep getting faster, the problem with that is every time you get a speed bump from faster hardware so does your competition. Adding to that problem is the fact that Maxwell requires that you buy render node licenses, I never understood this and it's a big reason why Maxwell will never be a widely used engine. I will probably never use Maxwell again because of the poor way Next Limit treated their customers during the Alpha/Beta/RC days. This is another point of contention for me as the usefulness of a product can be directly tied to the quality of support it receives from the developer. I left Final Render for the same reason, they were both too slow to respond to customer issues when it counted that's why Vray is my engine of choice now. I can do 10 times the work with Vray at a low cost with great support and terrific quality, what more can you ask for? Link to comment Share on other sites More sharing options...
MBetke Posted August 11, 2011 Share Posted August 11, 2011 I see you use Octane. Can it be used for rendering exteriors of small residential buldings? I see they say that you have a memory limit of what you can render... Yes if you dont use a lot of vegetation high-res assets. MEmeory is bound to the GB of the GPU you have like most GPU renderers. but it's biggest handicap will always be its speed. I totally agree. I got a animation job and did some tests for it. Basically I need to render around 130 furnished 80° top down turntable animations in a DVD resolution for a client to showcase his apartments. I tried Maxwell and it was not useable for this task because every second counts and I dont want to do it on a renderfarm. With Octane I can do it in a blaze 2min vs. 30sec per frame. Its a big differene if you multiply 100frames * 130 clips * 120second or 30seconds plus the voxelisation and export time for each frame. Sticking with Maxwell would need A) a hired renderfarm or B) my own one with rendernodes. On the other hand Maxwell is designed for people which need physical correct calculation and its still best in this task. Link to comment Share on other sites More sharing options...
AJLynn Posted August 11, 2011 Share Posted August 11, 2011 No, Maxwell is designed for people who want that look but don't want to spend the time getting it (or learning how) in Vray or mental ray. Physical correctness is marketing. Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 11, 2011 Share Posted August 11, 2011 Great point Andrew! Link to comment Share on other sites More sharing options...
theory Posted August 12, 2011 Share Posted August 12, 2011 from personal experience, maxwell render makes far more sense than Mental ray. and vray is just convenient and makes life easier with all the toys and what's not, and at the end the renderer plays only a small role as opposed to the artist's role in creating a beautiful render, i ditched all the other renderers and i'm currently a happy maxwell render v 2.5 user, Link to comment Share on other sites More sharing options...
tecton3d Posted August 12, 2011 Share Posted August 12, 2011 Yes of course. But you have to buy render nodes. ... does this work with FIRE - similar to Vray RT @ 8:30 here? Link to comment Share on other sites More sharing options...
theory Posted August 15, 2011 Share Posted August 15, 2011 yes daron it does, works through the 3d software, the standalone studio application, and also the material editor, Link to comment Share on other sites More sharing options...
