mu_688687 Posted September 1, 2010 Share Posted September 1, 2010 Hi All I'm facing problem in 3d max V-ray system Dynamic Memory as I have a 64 bit win 7 with 8 gb ram but I'm unable to use it as I can only able to put 3000 mb as a Dynamic memory in V-ray system screenshot also attached for your reference kindly pls see and suggest. Link to comment Share on other sites More sharing options...
francosd Posted September 1, 2010 Share Posted September 1, 2010 You can not use all your 8 gig-ram , you will leave windows with no memory to work windows uses 2 gig + the memory for max + bitmaps, graphic interface , etc Link to comment Share on other sites More sharing options...
mu_688687 Posted September 2, 2010 Author Share Posted September 2, 2010 Does it use 3000 mb or we can increase that aswell??? Link to comment Share on other sites More sharing options...
the_crown Posted September 7, 2010 Share Posted September 7, 2010 first as what francosd said the OS need his own memory space to use it for the other applications, secondly this is not the memory that the vray will use only this is special kind of needs for vray : Dynamic memory limit - the total RAM limit for the dynamic raycasters. Note that this limit is divided between the number of rendering threads. If you specify 400 MB total limit, for example, and you have a dual processor machine with multithreading enabled, then each rendering thread will use 200 MB for its dynamic raycaster. If this limit is too low, and geometry needs to be loaded and unloaded very often, this may turn out to be slower than rendering in single-threaded mode. http://vray.us/vray_documentation/vray_system.shtml Link to comment Share on other sites More sharing options...
