Andrew1 Posted September 3, 2010 Share Posted September 3, 2010 Hi there, Just wondering if anyone else had a similar problem , I was just testing away last night on an exterior scene practicing exterior lighting, suddenly maxs viewport started lagging horribly..., I opened task manager and notice my small scene was using 7.5 gigs or ram resources.. wtf ??? , it came to a point that max was locking up and I had to manually shut it down, I dont have the poly count but it was only in 1000s range - NOTHING for my system.... I couldn't believe it that my 64 bit system was choking on a simple scene like that, I tried to switch from DX9 to DX10 in direct draw display mode , max started to crash, I was trying to downsize my maps I was using, nothing was helping...., eventually I started removing objects and watching the task manager resources display however my mameory usage was not dropping .... as GPU I am using ant ATI card Sapphire I think 4890 HD 1 or 2 gigs - dont remember as I am at work...., I heard it maybe the ATI card ??? anyone ??? at the end I ran a small trick and switched my display from Direct Draw to Open GL and that seemed to stabelize max and the viewport behaviour.... am I the only one with the problem ? thanks for any replies. Andrew Link to comment Share on other sites More sharing options...
greyowl Posted September 3, 2010 Share Posted September 3, 2010 Sometimes turning off the viewcube can help. Link to comment Share on other sites More sharing options...
bev.lynn Posted September 3, 2010 Share Posted September 3, 2010 Here is the link from autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12572028&linkID=10381719 and http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11027531&linkID=10381719 I found this to be a big help. Link to comment Share on other sites More sharing options...
Andrew1 Posted September 4, 2010 Author Share Posted September 4, 2010 thank you guys, strange !!!!, it does work !!! , I dont use the cube thing, Im used to shortcut keys, I found the the cube annoying and in the way , I had that disabled long time ago, but what I did was, I renamed that file as indicated and my comps using only 3 gigs of resources right now with the same scene... thank you , I am back at direct draw and dX 9 and all works fine. I am gonna update my ATI drivers as well.... thanks again, Andrew. Link to comment Share on other sites More sharing options...
