Vray render problem
mrath04
when your sun is quite low in the sky it will always gice you a very "warm" light.
you could try and adjust your white balance in the physical camera to compensate (but it's very hit and miss unless you've got Vray RT)
The way I do it is to render out all of my images and then batch process them in lightroom or adobe camera raw to correct the white balance and exposure to whatever I need. also render out 16bit images so you can rescue burned highlights/shadows.
This is a quick and dirty workaround, but it does save a lot of tinkering with you camera.
incidently, my usual settings when using vray sun/phys cam are;
vray sun intesity: 0.01-0.015
Cam:
F-Number 5.6
vignette: off (add later in post)
shutter 1/20
ISO: 100
everything else at default, unless I'm going for a special effect.
hope this helps, but I'd like to hear other peoples opinions too.
