bleedingboy Posted September 8, 2010 Share Posted September 8, 2010 Hi, I'm using 3D max right now, and I have several questions that some of you might be able to help me with. I've attached the photo for reference. Basic items that I know some would be able to share some info. (I apologize if, my tag is HELPANOOB. It serves as a TAG for searching some of my queries. usually, I document them.) QUESTIONS 1. How do I make a VRAY GLASS MATERIAL transparent and reflective at the same time? A: (to be updated later on, with the best answer. for other's reference) 2. How do I make a water material I've attached, transparent and the ripples are so effectively hi-lighted? A: (to be updated later on, with the best answer. for other's reference) 3. There are dark spots on the surfaces of my model that I want to remove, how do I remove them? Any method? A: (to be updated later on, with the best answer. for other's reference) 4. How do I make the light coming through the openings, a bit foggy? I understand It has to do with the light's volume. A: (to be updated later on, with the best answer. for other's reference) Hope you all could help. Thanks in advance. Link to comment Share on other sites More sharing options...
GUSN Posted September 8, 2010 Share Posted September 8, 2010 Hi, I'm using 3D max right now, and I have several questions that some of you might be able to help me with. I've attached the photo for reference. Basic items that I know some would be able to share some info. (I apologize if, my tag is HELPANOOB. It serves as a TAG for searching some of my queries. usually, I document them.) QUESTIONS 1. How do I make a VRAY GLASS MATERIAL transparent and reflective at the same time? A: (to be updated later on, with the best answer. for other's reference) 2. How do I make a water material I've attached, transparent and the ripples are so effectively hi-lighted? A: (to be updated later on, with the best answer. for other's reference) 3. There are dark spots on the surfaces of my model that I want to remove, how do I remove them? Any method? A: (to be updated later on, with the best answer. for other's reference) 4. How do I make the light coming through the openings, a bit foggy? I understand It has to do with the light's volume. A: (to be updated later on, with the best answer. for other's reference) Hope you all could help. Thanks in advance. Here you go buddy. http://www.spot3d.com/vray/help/150SP1/ Link to comment Share on other sites More sharing options...
