skip9 Posted September 9, 2010 Share Posted September 9, 2010 In a follow up to my last thread, which has had good feedback, Can you edit the boundary that the magic wand selects? there is a slight break in an area i want to select, therefore it selects the outside of it as well. Can i still use the magic wand and subtract the area by placing a line across the break to create a boundary or similar? Link to comment Share on other sites More sharing options...
Cad64 Posted September 11, 2010 Share Posted September 11, 2010 After making your initial selection with the Magic Wand, you can switch to the Marquee tool or Lasso tool, hold down the Alt key and then drag out a selection in the area you want to subtract from the selection. Or, hold down the Shift key and drag out a selection in the area you want to add to your selection. You can do the same with the Magic Wand, you can hold down the Alt key and click to subtract from your selection or Shift key and click to add to the selection. Link to comment Share on other sites More sharing options...
