server disconnect (windows) problem
I have the following setup:
1 server, w7pro
1 workstation, w7 ultimate
8 x nodes, xp64
All are connected via a LinkSys 16 port ethernet switch, rendering with backburner.
The problem:
My nodes keep dropping connection to the mapped drive on the server. I cant find a reason, it just happens on all nodes at the same time. I restart the server and all the connections work again.
Any ideas? It is currently very disruptive to my work....
Hello Tom, try to look out for how long is IP valitd cause switch usualy assign IP for some time period after nodes might try to reconnect again.. also try to implement static IP or chose some server version of windows casuse it can handle more conections at same time and generally i think is more apropriate to manage data transfers to nodes.. Take this with reserve.. only my toughts.. :)
ps: alos check for automount feature of drive.. i have same problem on win64xp node apears as unmounted until I mannualy open it.. i just think that i can write *.bat file to open that drive at startup.. doesn't know if it will work
Edited by cupsster
