aristocratic3d Posted September 12, 2010 Share Posted September 12, 2010 (edited) Hi, I built a model of bicycle. I need it within 10000 polygon. I made that. But when I export it to 3ds or obj it goes up to 18000 polygon. Why is this happening? please see attached image. [ATTACH]39079[/ATTACH] [ATTACH]39078[/ATTACH] Any help are highly appreciated. Thanks in advance. Edited September 12, 2010 by aristocratic3d attachment managed Link to comment Share on other sites More sharing options...
JonRashid Posted September 12, 2010 Share Posted September 12, 2010 Because when you import in it treats every face as a polygon. Try quadrify or one of the other methods that return your mesh to quads Link to comment Share on other sites More sharing options...
-MerlyN- Posted September 12, 2010 Share Posted September 12, 2010 either that, or you have some splines turned renderable, that are converted to meshes. Link to comment Share on other sites More sharing options...
nelpiper Posted September 13, 2010 Share Posted September 13, 2010 The quadrify modifier is not recommended from autodesk itself. Go here and download a very cool script that will remove the extra faces from your polygon. Hope it helps. Good luck. Link to comment Share on other sites More sharing options...
