C.Vestal Posted July 1, 2004 Share Posted July 1, 2004 OK, this might be an easy fix... I am trying to open curve editor in Max 6. When I click the button, I think it is opening off screen. I am at maximum screen resolution so I can not increase that... any suggestions?? thanks, Link to comment Share on other sites More sharing options...
Chad Warner Posted July 1, 2004 Share Posted July 1, 2004 If you ever had dual monitors, the window could be opening on what used to be other monitor. Either way, open the max.ini file and look for headers that have "position" in the name, with numbers like 162,356 as the value. If you see any numbers that are larger than the resolution of your monitor, change it to a lower number. -Chad Link to comment Share on other sites More sharing options...
C.Vestal Posted July 1, 2004 Author Share Posted July 1, 2004 thanks, that got it. Link to comment Share on other sites More sharing options...
