Standing seam roof valleys?
Dave Buckley
I'm looking at roofing a bit more in-depth than I have before and I'm currently working onna standing seam type metal roof.
I've been following the 3dats books as a guide to the different types of roofs as I have no architectural background.
However, After i've created the standing seam, i want to add ridge and valley caps.
The ridges are ok, but I'm struggling to get the valley caps looking as though they have been finished off correctly.
How do you guys normally go about this? Any special techniques. The 3DATS book just says, "do the same for the valleys as you did for the ridge." but it's not that simple.
I need to make sure the standing seams aren't overlapping and look like they have been finished off properly.
Can anybody guide me a little?
Here's what I have currently.
I was hoping I could use a sweep with custom profile and then somehow use that sweep to cut the standing seams back to its edge
A valley detail would usually have a u-shaped channel running underneath the standing seam, with the sheeting overhanging a little to allow rainwater to run-off into the channel. You could do this by either creating a box then booleaning the roofing out, or by selecting all the vertices along the edge and moving them up, with the edge constraint activated, to form the gap.
