Stereoscopic... Posted September 16, 2010 Share Posted September 16, 2010 (edited) Anyone know if there's a method for loading an image into the rendered frame window? Edited September 16, 2010 by Stereoscopic... Link to comment Share on other sites More sharing options...
Macer Posted September 21, 2010 Share Posted September 21, 2010 I haven't come accross a way to do this. Not too sure why you would want to though? You can load images using the ram player (rendering menu > ram player). Link to comment Share on other sites More sharing options...
datacrasher Posted September 24, 2010 Share Posted September 24, 2010 what do you mean for loading an image into the rendered frame window? in what software. More infomation needed Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 24, 2010 Share Posted September 24, 2010 Maybe this will work if you simply want to view a rendering inside of Max... http://forums.cgarchitect.com/attachment.php?attachmentid=36780&d=1272404868 Follow the instructions in the Jpeg. The click the drop down File menu, near the bottom thee is an option to view file. Click that, and then open your previous rendered image. Link to comment Share on other sites More sharing options...
BrianKitts Posted September 24, 2010 Share Posted September 24, 2010 To open an image in the Max frame buffer, under the "Rendering" drop down of the menu bar select "load image file". But keep in mind that this does not load it into the active rendered frame window, so you can't render on top of it if you wanted to do patch rendering for instance. For that you'll have to do some photoshop work. Link to comment Share on other sites More sharing options...
