High Res Render Crash
tcupp
If you are using a 32bit system then it is most likely to be a memory problem. You will have to convert the objects in your scene to vray proxies and tweak the vray rendering settings.
I would help if you post your current rendering settings.
cheers
I have little VRAY experience. I pretty much just hack my way through so using proxies is something new to me. Any direction here would be greatly appreciated.
I am on a 64 bit machine - 8 gig of ram. So, I would not think that memory is an issue. I did try taking the file for a 32 bit machine and it bombed out right away there.
With that said, it seems to always be crashing at the "Prepass". A screen cap of the render dialogue is attached.
As for my VRAY settings, they are also attached.
Thanks a ton for the help.
On a side note, I am attempting to render smaller regions but it does not look like it is going to work either.
Light cache did not work.
Neither did changing my default geometry/dynamic memory settings as suggested.
It seems to always crash right at the end of the first prepass. Can the amount of prepasses be modified...what controls that.
I am going to further explore setting up proxies but it does not look promising.
Edited by tcupp
