Peter M. Gruhn Posted September 19, 2010 Share Posted September 19, 2010 I have a downtown area. Roughly 4000' on a side. I'm trying to model the tree canopy by displacing a plane. The map is good enough. It works fine on small test models. But at actual size there is nothing. It looks flat. The best reason I can figure out is that MR displacement is locked to no more than a few inches. I've been working with parameters in Renderer: Shadows & Displacement; and in Special Purpose Maps: Displacement. Am I missing a set of controls somewhere? This implies "oh, no... you can't use displacement to throw up a mountain range" which strikes me as wrong. So I must be missing something. Clues? - g Link to comment Share on other sites More sharing options...
JustinTuaylou Posted September 28, 2010 Share Posted September 28, 2010 Are you using the "displace" modifier, or putting the displacement map in the material editor and applying the "(WSM) displacement" modifier? Justin Link to comment Share on other sites More sharing options...
jinsley Posted September 29, 2010 Share Posted September 29, 2010 Justin is on the right track... I have used a high density mesh, with displacement modifier and then simply mapped my diffuse, etc... with an alpha to it. worked great for aerials and distant shots... Link to comment Share on other sites More sharing options...
