gkanz Posted September 21, 2010 Share Posted September 21, 2010 Hello Folks. My first post, so wish me luck and please bare with me. I've been trying to add extra vertices to an object I've created ( in 3ds max) but with no luck. Seems that the help files and also going the "Google" route has only shown how to add vertices to SPLINES only. I'm definitly new to this program and I've got much to learn but I've worked in TrueSpace and the adding of edges and vertices were pretty cut and dry. Am I missing something here? Appreciate any help or step by steps. Peace. gk Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted September 21, 2010 Share Posted September 21, 2010 It's pretty simple, actually, and there are lots of ways. One I personally use is to select an edge and, in the modify panel, click Insert Vertex. Then, I simply click on the edge I want the new vertex to sit. That's it. Link to comment Share on other sites More sharing options...
nelpiper Posted September 22, 2010 Share Posted September 22, 2010 As an extra tip to Rick´s tip, once you´ve inserted your vertex on a edge, go to the modify panel and click on chamfer. If you chamfer a vert on a edge, it´ll actually duplicate it in equal distances. It´s pretty cool. Hope it helps. Good luck. Link to comment Share on other sites More sharing options...
gkanz Posted September 22, 2010 Author Share Posted September 22, 2010 (edited) Greetings to both Mr. Eloy and Nelpiper. Appreciate both your quick replies. I wrote a comeback to Mr. Eloy's reply yesterday evening but for reasons unkown it never made up here. Anywho, I'm glad that it didn't make it up 'cause it would have made me look like an idjot. I really don't know how I missed that dang on "Insert Vertex" button but I did. Many times. Oh, well I'll just mark it up to climate change. Thanx, again to you both. Hope we can do this again sometime, I'll try not to make it so easy for ya Peace. Have a good one. gk Edited September 22, 2010 by gkanz Link to comment Share on other sites More sharing options...
datacrasher Posted September 23, 2010 Share Posted September 23, 2010 (edited) The only way i have found out is by running a connect though the poly turn edge faces on in the sub-object choose the edges level example select the left edge and then hold the control button and select the right edge under edit edges choose choose connect. In the p.view max will show you a line you can slide and pinch the lines together if you have more then one. Once you have done this then click the ok button you can see more Vertices when you select the Vertices sub-object you should have really added the amount of segs before you converted it down Good luck DC Edited September 23, 2010 by datacrasher Link to comment Share on other sites More sharing options...
gkanz Posted September 25, 2010 Author Share Posted September 25, 2010 Appreciate Mr. Datacrasher. I guess another way to get a few extra vertices in my mesh ( a bit complicated tho for this beginner). I will give 'er a try. Peace. Thanx again. gk Link to comment Share on other sites More sharing options...
