vozdra Posted September 22, 2010 Share Posted September 22, 2010 hey guys, i imported a model from sketchup and wanted to apply a rusty metal material to the surface. I only wanted to apply in to one surface and not the whole object so i converted it to an editable poly and added the materials to the surface while the polygon selector was selected. hopefully that makes sense. When i went to render the image the scene showed just a single colour and not the material?? i created a box right next to it in max and applied the same material and it applied to the material and works fine. the process used for applying material was material editor- vraymtl - selected box next to diffuse- bitmap- selected my material then applied it i dont know if its the model that i imported from sketchup?? Im not sure what the problem is?[ATTACH=CONFIG]39286[/ATTACH] HELP! Link to comment Share on other sites More sharing options...
vozdra Posted September 22, 2010 Author Share Posted September 22, 2010 u just tried making a simple box and importing into sketchup and i made a box next to it in max. Then max box material work where as the sketchup imported box didnt. it just came up with a colour so im assuming it has something to do with the sketchup file Link to comment Share on other sites More sharing options...
Stephen Thomas Posted September 22, 2010 Share Posted September 22, 2010 The difference is that a box created in max will have inherent UVW mapping while the sketchup mesh will not. All you have to do is apply a UVW map modifier to the object and it should be resolved. Link to comment Share on other sites More sharing options...
vozdra Posted September 22, 2010 Author Share Posted September 22, 2010 The difference is that a box created in max will have inherent UVW mapping while the sketchup mesh will not. All you have to do is apply a UVW map modifier to the object and it should be resolved. it worked. thanks! Link to comment Share on other sites More sharing options...
