Ausmax Posted September 26, 2010 Share Posted September 26, 2010 Hello, Would someone be able to help. I have am using a muti/suboject material and within that I have a arch & design material with a brick bitmap in the colour slot. I have been trying tweak my settings within the material but every time I adjust it, the loft renders black and then I can't get my material to appear again. Has anyone got any idea what might be happening here? I was thinking that it might be the geometry within the loft but not sure?? Any suggestions would be most helpful Cheers Link to comment Share on other sites More sharing options...
ramy Posted September 27, 2010 Share Posted September 27, 2010 Two things: • make sure your geometry face ID's match the Multi/Sub Obj. ID of the arch&design material you're using • a UVW modifier needs to be applied to your geometry so that the material can be correctly projected Link to comment Share on other sites More sharing options...
abmitalia Posted September 28, 2010 Share Posted September 28, 2010 What are you rendering with? Vray doesn't see arch&design mat. RK Link to comment Share on other sites More sharing options...
Thablanch Posted September 28, 2010 Share Posted September 28, 2010 Vray handles arch&design materials ( since version 1.5 if I recall ) Vray does not handle PorMaterials. It actually convert arch&design mats on the fly at rendertime. Link to comment Share on other sites More sharing options...
abmitalia Posted September 28, 2010 Share Posted September 28, 2010 ups Link to comment Share on other sites More sharing options...
