jucaro Posted October 1, 2010 Share Posted October 1, 2010 Hi, does anyone know of a way to assign multiple materials (NOT multi/sub object matrial) on a single object then render those materials by element via multiple VrayMtlSelect. This would really be great help rendering a floor with a lot of carpet/tile options without having to reassign a map and re-render a region. Link to comment Share on other sites More sharing options...
notamondayfan Posted October 1, 2010 Share Posted October 1, 2010 if its just simple colour changes, you could use the diffuse pass (so long as you are compositing with elements) to change the colours. or you could animate the material, and render several frames for your variation? Link to comment Share on other sites More sharing options...
jucaro Posted October 1, 2010 Author Share Posted October 1, 2010 Unfortunately, its not just a simple color change. Color changes is easy to remedy with just a mask. But carpet/tiles pattern change is tedious. Rendering a selection and changing the map for every carpet pattern is no walk in the park when you have about a hundred more to go. Link to comment Share on other sites More sharing options...
erickdt Posted October 1, 2010 Share Posted October 1, 2010 You could mask out all other objects other than your flooring. You do this by right clicking with all of your objects selected that you want to mask out, click on vray properties, check matte object box, set alpha contribution to -1.0. Then if you hit render only your carpet/flooring will render drastically cutting down your render times. E Link to comment Share on other sites More sharing options...
