Arch-Vis Posted October 8, 2010 Share Posted October 8, 2010 Studio/Institution: Arch-VisGenre: Residential ExteriorSoftware: 3ds max, Vray, photoshopWebsite: http://www.arch-vis.co.ukDescription: Hi All. Another residential exterior I've been working on. All comments welcome. Thanks Andy Link to comment Share on other sites More sharing options...
heni30 Posted October 8, 2010 Share Posted October 8, 2010 Hi, Everything looks great! Only thing - for me - is that the grass looks a little too yellowish. Here is a comparison. Also, I think darker provides a more substantial base for the building. Link to comment Share on other sites More sharing options...
TheAllusionisst Posted October 8, 2010 Share Posted October 8, 2010 The rendering on the technical side is beautiful. The choice of wood siding color (aged cedar?) is a bit perplexing and the use of brick is inconsistent. Even if you were to switch to low wainscot, I do not understand why you terminate it like you do, it doesn't follow any set rules, if it is just on the nooks in some places, that should be consistent. You may wonder why I would bring these items up, but architectural design can make or break your image. Rendering is beautiful, just architecturally un-spectacular. Link to comment Share on other sites More sharing options...
Arch-Vis Posted October 8, 2010 Author Share Posted October 8, 2010 The rendering on the technical side is beautiful. The choice of wood siding color (aged cedar?) is a bit perplexing and the use of brick is inconsistent. Even if you were to switch to low wainscot, I do not understand why you terminate it like you do, it doesn't follow any set rules, if it is just on the nooks in some places, that should be consistent. You may wonder why I would bring these items up, but architectural design can make or break your image. Rendering is beautiful, just architecturally un-spectacular. Thanks for the comments, taken onboard. Unfortunately though I have no say on the architectural side of things, but I will suggest this to the end client. Link to comment Share on other sites More sharing options...
neil poppleton Posted October 10, 2010 Share Posted October 10, 2010 The roof material needs looking at. A cleaner crisper slate may work better, it looks a bit scruffy and non impressive. Link to comment Share on other sites More sharing options...
nanasba13 Posted October 15, 2010 Share Posted October 15, 2010 I agree with TheAllusionist, other than that rendering looks great, and I believe the yellowish grass actually looks better. P.s Did you add the grass in PhotoShop? Link to comment Share on other sites More sharing options...
Arch-Vis Posted October 15, 2010 Author Share Posted October 15, 2010 Thanks for the comments. The grass was made in Max. Link to comment Share on other sites More sharing options...
Joseph A Haddad Posted November 1, 2010 Share Posted November 1, 2010 Nice picture but how actually did you do the grass in Max? did you use forest pro? Link to comment Share on other sites More sharing options...
Arch-Vis Posted November 1, 2010 Author Share Posted November 1, 2010 Thanks. I modelled it and scattered it accross the ground mesh. Link to comment Share on other sites More sharing options...
