Removing the Haze
bev.lynn
I have "0", none, nada, Photoshop experience and need to remove the haze from the attached image.
Can someone give me step-by-step instructions on how to do this (if it is possible)?
I am using Photoshop CS2.
Thanks,
Bev
[ATTACH=CONFIG]39604[/ATTACH]
[ATTACH=CONFIG]39605[/ATTACH]
There's probably better more advanced ways... but I find a simple Curves Adjustment is a good start for this type of thing.. You could probably get into some levels adjustments too...
you can either go to Image>adjustment>Curves or apply an adjustment layer by using the half black/white cookie looking circle at the bottom of the layer pallette..
In this particular case I did the whole curves once on their own, the it looked a little too green and red... so I lowered those curves individually.
Thanks Michael,
Using the Curves Adjustment works well for what I'm doing.
Learning is awesome! All I need is about 48 hours in a day, the hands of time turned back 25 years and I could master 3ds max design and photoshop in a couple of weeks!
LOL, if you've learned 3D max 10 years ago, half of what you know is useless by now!
