harryjacob Posted October 13, 2010 Share Posted October 13, 2010 Is it possible to render a parallel viewed model in sketchup via vray? Cause when I render a model in parallel view in sketchup, the output rendered image in vray turns out to be in perspective view. Are there settings that I should change in vray options for the view of camera in vray to be parallel? Link to comment Share on other sites More sharing options...
Sketchrender Posted October 13, 2010 Share Posted October 13, 2010 Well in max with Vray you can't. Link to comment Share on other sites More sharing options...
manojglobal Posted October 18, 2010 Share Posted October 18, 2010 I fully agree with philip... Thanks Manoj Singh Link to comment Share on other sites More sharing options...
RayOfLight Posted October 19, 2010 Share Posted October 19, 2010 I'm not sure what you mean by Parallel View, you mean Orthographic or 2D (like a side/top/front view?) Both are possible, at least in 3dsMax. Orthographic: use guess vertical and guess horizontal, make sure the camera has enough distance, and when needed, use zoom to get the object closer 2D view: place camera at long, very long distance, use very high zoom and narrow FOV to get to object close enough. It isn't true 2D, but you won't have to see the difference! Link to comment Share on other sites More sharing options...
Evren Cavusoglu Posted November 6, 2010 Share Posted November 6, 2010 hello when you select parallel projection and set the front with views and select zoom tool you can see bottom right field of view 35 set to 1 try Link to comment Share on other sites More sharing options...
