carlotristan3d Posted October 14, 2010 Share Posted October 14, 2010 At sub-object level, is there a way to randomly select polygons. I'm trying to trim down the leaves on my 3d trees for an autmn scene. Paint select region does not do the trick. thanks. Link to comment Share on other sites More sharing options...
Dave Buckley Posted October 14, 2010 Share Posted October 14, 2010 there is a way using the graphite tools, in fact you have a number of different ways, you can randomly select based on what you are looking at in perspective/camera view, or you can randomly select in general. select the editable poly object go to poly mode deselect any that may be selected go to the selection tab on the ribbon then have a play with all the different methods you should have different panels 'by normal' 'by perspective' 'by random' etc etc should do the trick Link to comment Share on other sites More sharing options...
carlotristan3d Posted October 14, 2010 Author Share Posted October 14, 2010 Thanks Dave. Got it! Link to comment Share on other sites More sharing options...
Fooch Posted October 14, 2010 Share Posted October 14, 2010 You can use scripts to random select stuff. http://www.scriptspot.com/3ds-max/scripts/random-select-v1-0 Link to comment Share on other sites More sharing options...
postite Posted October 15, 2010 Share Posted October 15, 2010 Hi, I suggest using the modifier "material by element" in poly. You can check the random distribution option, with X different material. Link to comment Share on other sites More sharing options...
