I need these lights to glow?
Akira329
Studio/Institution: Freelance
Genre: Residential Exterior
Software: 3dmax 2011/mental ray
Description:
Hey Guys!
I need some help to make these lights to glow?
Is there shaders or effects that will help?
Right now I'm using the self illuminating (glow) effect but I not getting the 'glow' that I need.
Is this something I will have to do post production?
Thanks and any other comments would be greatly appreciated!!
Antaiwan
Try this.
Duplicate your base layer. Blur it by a good amount until the edges of your image blur out, switch to softlight. Add a layer mask to it and invert that mask. Paint your mask over the lights.
To give more "punch" to it, make a black layer. Set the layer to colour dodge. Then use the brush tool at say 30% - 70% transperancy. Make sure the edges are soft. Paint it in.
Control glow amount with your "fill"
I agree with Dave; use the glare shader. Also, make sure that you have those emitters visable in reflections and illuminating the scene. Personally, i'd throw a small photometric there to get the glare to respond correctly. G/L
I cannot get the glare to work?
I'm use rectangle area lights, could this be the reason?
Okay I used points lights first and the glare worked. So the area lights are different how?
Also fooch thanks for post! I was considering doing that instead but wanted to be sure max could or couldn't do this!
Looks great though!!lol!!
No worries. I'm a heavy post guy so a lot of my workflow is post based.
Check out the layer structure on the attached image previously.
I would duplicate the layer, blur it and set the blend mode to softlight or screen.
Layer mask is on the bottom right of photoshop and when you add a layer mask it would be white (which means 100% transparent) , Click CRTL+I to invert the mask to pure black. Then get a brush, soft edges and set it to a say 30% transparency and paint white into the layer mask. This will reveal the "blurred" layer which is on a blend mode that gives the glows.
Plus, to make it kick out. (The top layer) A solid black layer in photoshop , set it to color dodge for the blend modes and paint in lights with a 70% brush (white or a tint of yellow) .. You can tune down the lights with fill.
Edited by fooch
Going a different route.
Night scene!
It just felt all wrong to have the lights glow during a day scene anyway.
I still need to do some touching up though.
Also thanks Fooch for the help!
Comments about this one would be helpful!
Antaiwan
Well you can punch a few curves in. Get more colour bleeds.
I would duplicate the base layer, blur it by 2 pixels (gaussian) and set that to softlight. Then mask in where I want some lights / soft diffusion to come in. Plus i would colourize that softlight layer (via hue) to tint your lights a certain colour.
Here's the psd file for reference. Note, if you are rendering, safe it to an exr or a 16 bit image so you can manipulate colours further on. It gets pretty crunchy on a jpg and you can lose heaps of info.
PSD: http://rcpt.yousendit.com/974413651/905f68eac4bc0b8ef9a13719e0fc4172
  • 2 weeks later...
Get proexr for photoshop.
Or 16 bit tiffs at least to allow some freedom to change colours
Another tip. When stumped for time, bring in a lighter gamma version from exr .. which you can mask in later ..
Kinda like using HDRI images except its rendered files.
