Alyosha Posted October 18, 2010 Share Posted October 18, 2010 Hello, I have this idea of making a surface reflective, but in a way that reflection would stick to certain color. For example, i have a plane with 100% reflectivity, which reflects blue sky and clouds as blue sky and clouds. I want it to reflect sky as dark grey, not blue though - now here is the problem; when i use "reflection color" other than merely whites and blacks it works OK, but how on earth do I convince it to use GREY as reflection color, since it only uses greys to determine intensity of the reflection, but doesnt actually add grey color to it as it would if one chose saturated violet for example. Or, how do I obtain desaturated, dark grey reflection? any thoughts? Link to comment Share on other sites More sharing options...
Camby1298 Posted October 18, 2010 Share Posted October 18, 2010 If your scene is as simple as you describe, than use 2 different sky domes. One will be fully colored, the other will be desaturated as you want to appear. The fully colored Sky Object Properties, will be visible to camera, but not visible to reflection/refraction. Whereas the desaturated sky Object properties can be non-visible to camera, but visible to reflection/refraction Link to comment Share on other sites More sharing options...
Alyosha Posted October 18, 2010 Author Share Posted October 18, 2010 hey, yeah i thought of that but i just want the desaturated reflections on one element in the scene, on the rest it should reflect normally, otherwise i'd just use bw map in reflection slot of the environment rollout, i dont use domes anyway i use the environment slots i thought about creating a sky object/dome just for this particular reflection, but i cant turn off the normal environment slot reflections anyway, so i am looking for a more elegant, material-based solution basically i have these grey photovoltaics which i want them to have this clearly defined shine and reflection, but i want it to remain grey, not reflect sky as blue but only reflect it's high and low values basically Link to comment Share on other sites More sharing options...
CliveG Posted October 18, 2010 Share Posted October 18, 2010 Just a thought.... anything you can do with a VrayOverrideMtl? Obviously you can allocate completely different materials for reflectance or refractance than the base material. I don't know if this can be used in the Dome light slot but it could certainly be used for your reflecting material. CG Link to comment Share on other sites More sharing options...
Alyosha Posted October 19, 2010 Author Share Posted October 19, 2010 yes but override mat is a generator, i am looking for a solution on the reciveing end (the affected mat) Link to comment Share on other sites More sharing options...
Stephen Thomas Posted October 19, 2010 Share Posted October 19, 2010 How about using the environment slot in the material? Link to comment Share on other sites More sharing options...
Alyosha Posted October 19, 2010 Author Share Posted October 19, 2010 that sounds promising stef!! thanks for the idea, i'll try it out later and let you know how it worked! Link to comment Share on other sites More sharing options...
Ismael Posted October 27, 2010 Share Posted October 27, 2010 This should help if understood and applied... http://www.neilblevins.com/cg_education/metal_and_refs/metal_and_refs.htm Link to comment Share on other sites More sharing options...
aristocratic3d Posted October 28, 2010 Share Posted October 28, 2010 Gray sky map can be used in environment slot and that will work for sure. However it may seems fake. Link to comment Share on other sites More sharing options...
Alyosha Posted October 28, 2010 Author Share Posted October 28, 2010 well most architects i work for are like "the faker it looks the happier we are"...it's the idea of a client^^ Link to comment Share on other sites More sharing options...
