davidkwan Posted October 19, 2010 Share Posted October 19, 2010 Hello, I'm new here. I'm now using FryRender v1.5 to do some test. I find that even I change the setting of f-stop and ISO (default should be 5.6 and 100, I set it to 22 and 50) and then go rendering a sequence, there only the first frame will follow the setting, after that, the setting will turn back to 5.6 and 100 for all the frame since frame two. Is it a bugs of FryRender? (I read the camera and ISO setting about current render frame by activate the "Overlap info tab") And also, I find the setting of "render single frame" is useless inside because it will only render the first frame all the time after activated. It won't obey the current time slider position for single frame rendering...... Link to comment Share on other sites More sharing options...
