v-tool Posted October 19, 2010 Share Posted October 19, 2010 hello everyone, im working in animation which includes compositing some moving cars in real footage. i did cammera tracking, i animated cars and now im stuck at rendering animation for later coposition in After Effects. I need help how, can i set up scene and which pases should i render for best composition later. im using vray anyone knows any good tutorial i would appriciate help thnx Link to comment Share on other sites More sharing options...
thatch Posted October 22, 2010 Share Posted October 22, 2010 Aton, you should add all the vray elements which are present in your scene. If its just cars you would probably need. Diffuse RawGI Raw Lighting Relection Refraction Specular zdepth Multiply the diffuse with both the gi and lighting then add everything else together. I don't use after effects so cant help you with that. I would make all your lights in the scene white and change the colour in your comp too. You will also need a shadow pass, create another instance of your cars and make them not visible to camera, then make your ground a vray matte with -1 on alpha, check shadows option. I would recommend investing in RPmanager if you are doing lots of jobs like this, it will save you lots of headaches! The chaosgroup forum has more users who do this kind of thing. try posting there too. Link to comment Share on other sites More sharing options...
v-tool Posted November 2, 2010 Author Share Posted November 2, 2010 thnx thatch, im following your advice, and im doing good for the moment Link to comment Share on other sites More sharing options...
