Vray flythrough with exposure changes and a sunset...
Roodogg
Hi Everyone. Apologies if this has already been resolved on the forum but I couldn't find it...
I am rendering my first flythrough animation where the sun sets. The camera flys round a building, pauses, the sun moves across the sky, the camera then enters an atrium, the sun sets, artificial lights illuminate.
My usual scene is set up with vray sky (instanced between environment, vray environment / reflect / refract)
Vray sun,
Vray physical camera.
Primary irradiance map (Animation - prepass / rendering)
Secondary light cache (Flythrough mode)
Each frame renders perfectly until the sun sets. When rendering in sequence, the light level remains the same during the sun set (The sun drops though it remains daylight). If I render each frame individually, the light diminishes correctly.
Obviously the problem is the light cache, it works if I use single frame mode but then the animation flickers. Using brute force as the secondary GI works but it takes ages and I'm under time constraints!!!
Is there something I'm missing, I've tried every setting within light cache plus I know photon map is useless.
Many thanks for any responses.
Any help would be much appreciated
3DS MAX 2010 64bit
Vray 1.5 RC4
Intel Quad Q6600 2.4Ghz
8GB RAM
  • 1 month later...
  • 2 months later...
It's because you're animating your lights, animating using that method will not work. Check out this tutorial, it's a guide on how to animate object or lights in an animation with GI and no flickering - http://www.spot3d.com/vray/help/150SP1/tutorials_anim2.htm
Craig:
Thanks a lot... now evrything is clear.....!! im rendering entire sunset animation actualy (will show you soon)....
and i have another question jejeje...
now we have that setting about camera path... but... what happend if i precacluate a simply fly through (no movement just camera) with that setting on? is it necesary? or i just have to do it in past way?
thanks...!
rafa
