Vertical posts along a 3D spline
PellePixel
How place an array of posts creating a fence there everybody should be vertical even if the spline is 3D? Tried Spacing tool & Follow that is near the solution... all posts follows in the tangent direction but they are not vertical.
Think I did this in an early 3Dmax version but forgotten how.
Using several hundred posts when making road barriers.
  abicalho said:
Don't use Follow and they should all remain vertical.
Yes, but if you have an shape/section on the post (most common) that have to follow the spline when it turns then it will not work (?) - the posts will (without "follow") keep the same direction
For example a post with a rectangular section should of rotate with the spline when it turns.
I see now. I don't know of a solution except when using MAXScript.
Do this: create all your clones with Follow. Then select them all, open the MAXScript Listener and evaluate these 2 lines:
for i in selection do i.rotation.x_rotation = 0
for i in selection do i.rotation.y_rotation = 0
Now your posts should be rotated only in Z, and all vertical.
If they show upside down, set the X rotation = 180 instead of 0.
Let us know if it works.
Alexander
